Modifications to build .deb package
lyc1
I'd like to maintain .deb package for Ubuntu.
FreeFileSync uses its own configuration folders to read Resources.dat,
Languages files and to write user configuration. These are incompatible with
building .deb package.
Would it be possible to use wxStandardPaths::GetDataDir for languages,
GetResourcesDir for Resource.dat and GetUserDataDir to store user generated
files ?
Moreover, Makefile is missing "install" target which is very useful to build
.deb package, where install prefix is configurable.
Maybe a reworked build system based on Makefile.in + configure could be
necessary (i don't know much about that).
I well want to provide patches and test results on Ubuntu, but I need your
help to understand FFS organization.
Hi lyc1!
Alright, let's go for this.
GetResourcesDir > for Resource.dat and GetUserDataDir to store user generated
files ?
Yes, I'll adapt file loading accordingly. There is just one thing to consider:
For Windows there are two types of FFS: "installer-based" and "portable". For
Linux there is only "portable". The main differentiator between the two when
it comes to Linux is: Where is user configuration/data supposed to be saved?
So we would need some means to determine whether FFS is running portable or
installer-based.
I'm thinking about something like: If FFS binary is located "bin" directory it
is installer-based version, else portable.
.deb
necessary (i
I'm not sure if Makefile.in is required, it may be that adding an "install"
target is sufficient.
Regards, Zenju
lyc1
> The main differentiator between the two when it
Hum, what is a user configuration/data for you ?
FFS remembers last user ui appearance, in a xml file. Such a file could to go
to GetUserDataDir().
User configuration files could go where the he want to save them, with default
value sets to GetDocumentsDir() or GetUserDataDir() for eg.
According to the doc:
wxStandardPaths::GetUserDataDir
* Unix: ~/.appname
* Windows: C:\Documents and Settings\username\Application Data\appname
* Mac: ~/Library/Application Support/appname
wxStandardPaths::GetDocumentsDir
* Unix: ~ (the home directory)
* Windows: C:\Documents and Settings\username\Documents
* Mac: ~/Documents
wxApp::GetAppName() should be set too ("FreeFileSync" or "freefilesync")
> If FFS binary is located "bin" directory it is installer-based version, else
portable.
It could work.
> it may be that adding an "install" target is sufficient.
During .deb build, install prefix is set to a temporary folder (thanks to
configure) in order to build the binary package later. So this needs to be
configurable.
But a user which wants to install it manually, will just sets prefix to /usr
(default) or /usr/local
Lyc1
Configuration data the program creates by default:
LastRun.ffs_gui
LastRun.ffs_real
GlobalSettings.xml
Logs\* (default directory)
Error.txt
default value
I use wxFilePicker control for this, at least in Windows it remembers the last
selection, so this should be okay.
else portable.
>It could work.
This solution doesn't seem to be very elegant. But I don't see a better one
right now.
configure) in > order to build the binary package later. So this needs to be
configurable.
(default)
> or /usr/local
Okay, then we'd need a "configure" file for setting the installation path (if
nothing else).
lyc1
> LastRun.ffs_gui
> LastRun.ffs_real
> GlobalSettings.xml
> Error.txt
Ok => GetUserDataDir()
> >It could work.
> one right now.
I don't understand what are the differences between installer-based and
portable version.
File structures are not the same ?
> path (if nothing else).
I think it's the main missing configuration settings, with "make install"
target.
.deb packaging is ready, I'm just waiting for theses modifications. I'll setup
an Ubuntu PPA as soon as it will work.
portable version.
Exactly, in portable mode all files are saved into the directory containing
the binary. Usecase is carrying FFS around on a USB-stick. For Linux this
might not be so common, but it doesn't cost me anything to support it.
target.
setup an Ubuntu
Is it possible to also set application icons?
Today I'm trying to finalize v3.3 and hopefully release it. Perhaps I find the
time to include the changes to file loading also.
lyc1
> containing the binary. Usecase is carrying FFS around on a USB-stick.
> For Linux this might not be so common, but it doesn't cost me anything
> to support it.
FFS is currently "installed" for testing purpose on my usb key (Linux
compilation).
It works perfectly :)
May be you could implement the opposite idea : why not testing "FFS is in
portable mode" instead of testing "FFS is in installer-based mode" ?
Ubuntu installation will be a kinf of installer-based mode too.
If FFS find Resources.dat or folder of languages beside executable file, it is
in portable mode, isn't it ?
> > I'll setup an Ubuntu
What do you mean ?
> > find the time to include the changes to file loading also.
If it's not ready for 3.3, I'll work with CVS HEAD of FFS.
is in
Good idea. Seems to be more safe than checking whether path of binary ends
with a "\bin", or checking directly against "\usr\bin" or "\usr\local\bin".
> What do you mean ?
In Windows each binary contains an icon resource. For Linux there is an analog
approach requiring registering icon files in some special folders. I don't
know if such registering belongs into a .deb package, but if it does, it would
be nice.
CVS isn't maintained anymore, instead you can use the current source-files
that come along with each releas as a .zip package.
lyc1
> > What do you mean ?
> an analog approach requiring registering icon files in some special
> folders. I don't know if such registering belongs into a .deb package,
> but if it does, it would be nice.
FFS will be available in Ubuntu "Application=>Accessories" menu with its own
usual icon.
I'll provide you FreeFileSync.desktop file later.
lyc1
> the current source-files that come along with each releas as a .zip package.
Hum, I will have to wait 3.4 release since you released 3.3 version yesterday.
In the future, It would be good to be able to have daily sources snapshots
available, or better scm access, in order to test packaging before each
release.
Other modifications I will do :
- disable by default checking of new version
- disable menu entry to check new version
Later (external dev, but may need FFS improvements) :
- Default association between .ffs_gui extension and FFS
- Nautilus extension with menu entry such as "Synchronize this folder with FreeFileSync"
yesterday.
> packaging before each release.
I didn't find the time yesterday to include the adaptions to file loading, but
will implement it today. Then I'll post a link the the sources here, so that
you can test. In the long run I think it won't be necessary to have daily
snapshots when it comes to packaging, as the algorithms, once implemented,
should prove to be stable.
Why disable update-checks?
Would be nice.
FreeFileSync"
I'm not sure, if there is valid usecase for this. But even if, it would need
to have an option to select if this change is applied.
lyc1
> loading, but will implement it today. Then I'll post a link the the
> sources here, so that you can test.
Ok, take your time, theses modifications are not urgent.
> implemented, should prove to be stable.
Ok.
Update check is system-wide and manage centrally on Ubuntu (on Linux in
general).
When FFS will be updated, Ubuntu package will be updated on its PPA, and, in a
day, all users will receive this new version.
This is a typical behavior on Linux.
For eg., Firefox or Thunderbird never tell me they will be updated. Automatic
update-check is disabled and delegated to Ubuntu update system.
> > with FreeFileSync"
> would need to have an option to select if this change is applied.
This is a feature often requested for Unison, another synchronization tool,
very popular on Ubuntu.
But Unison :
- can't be translated easily
- hard to configure for Ubuntu's beginners
- UI is very poor and very hard to extend because it is written in ocaml (?)
But I'll think about that really later.
> and, in a day, all users will receive this new version.
That's really cool! So I will disable update checks and links for the
installer-version, but keep it for portable.
lyc1
> So I will disable update checks and links for the installer-version, but
What about installer-based users ?
Maybe you could control this with a config file, specific for this feature. If
it exists and contains a specified value, doesn't check or display anything
about update. This file could be stored in GetLocalDataDir (executable dir on
Windows, /etc/FreeFileSync on Linux)
I could provide this file especially for the Ubuntu deb packaging.
You mean giving an option whether they want the regular update-checks
additionally? Shouldn't be necessary if the .deb package handles all updates,
should it? I think in the installer-based version it would be kind of
redundant having two kinds of update-checks.
lyc1
> want the regular update-checks additionally?
> Shouldn't be necessary if the .deb package handles all updates, should it?
Ubuntu update system will handle update-check and update of FFS alone. So FFS
update-check has to be disabled.
If you can disable this feature without any side effect on Windows platform,
it's ok for me.
Windows build won't interfere. I'll have this update check active in general
with Linux installer version being the only exception.
Alright, I've patched file loading for Linux. Here is the new structure for
the installer-based version:
Binary:
FreeFileSync
RealtimeSync
Resources (wxStandardPaths::GetResourcesDir())
Languages\*.lng
Help\*
Compare_Complete.wav
Sync_Complete.wav
Resources.dat
Changelog.txt
License.txt
Styles.rc
Generated files (wxStandardPaths::GetUserDataDir)
LastRun.ffs_gui
LastRun.ffs_real
GlobalSettings.xml
Error.txt
In Linux portable mode all files are read and written to the current working
directory. The algorithm to detect portable is: "portable" <=> not "binary
path ends with \bin". This ensures that if it is in any other directory, FFS
assumes portable mode by default, no matter if resources files reside besides
binary or not.
Additionally update checks have been disabled for Linux installer-based
version.
Updated source:
[404, Invalid URL: http://www.file-upload.net/download-2221782/Sourcecode_v3.4_RC.zip.html]
Regards, Zenju
lyc1
> Updated source:
It works great, either as portable mode or dispatched through /usr/local/bin,
/usr/local/share/FreeFileSync and /home/<USER>/.FreeFileSync
Update-check is disabled as expected.
Will you work on improving configure/Makefile (install) or should I do it
myself (with later contribution to FFS) ?
myself (with later contribution to FFS)?
You can make the adaptions to the makefile, I'll then incorporate them into
the current sources.
lyc1
Here we are, FFS is packaged as .deb file for Ubuntu.
It is available here :
[404, Invalid URL: https://launchpad.net/%7Edlecan/%2Barchive/ffs]
I had to improve Makefile in order to support install target, I had to create
.desktop file (Ubuntu menu configuration), create a 48x48px FFS logo png image
and restore FreeFileSync.xpm
I can contribute Makefile, 48x48px image. How ?
have to be lower-cased.
Other packaging stuff related to .deb will be available under GPLv3 and stored
into Ubuntu Launchpad SCM.
Great! I'll be testing this. About the files you created: You can simply send
them per mail or upload them somewhere and send me the link.
Regards, Zenju
The .deb package seems to working fine!
I've included the makefile into the sources and also updated the makefile for
RealtimeSync:
[404, Invalid URL: http://www.file-upload.net/download-2243670/FFS_v3.4_RC2.rar.html]
- Is it possible to include RealtimeSync also?
- Could you register file extensions and icons for *.ffs_gui, *.ffs_batch and *.ffs_real?
Thanks, Zenju
lyc1
> Is it possible to include RealTimeSync also?
Yes, I'll packaged it as separate bundle.
*.ffs_real?
It should be already done for .ffs_gui :)
If it doesn't work, it's a bug.
I'll try on a clean Ubuntu installation.
In this case there is one caveat: Currently RTS relies on "ossp_uuid" already
having compiled completely by FFS make. So the RTS makefile needs to be made
smarter, to also include "ossp_uuid". But the dependency in FFS makefile
(currently) is not correct:
target "FreeFileSync" depends on "ossp_uuid", while in fact only
"shared/guid.cpp" should depend on "ossp_uuid".
Could this be fixed by having "shared/guid.dep" depend on both
"shared/guid.cpp" AND "ossp_uuid" (possibly without removing "shared/guid.cpp"
from file list)? Hope I could make my point clear. :)
Yes, association is okay, but it doesn't have an icon associated with it. And
the other extensions, *.ffs_batch and *.ffs_real are not registered.
Regards, Zenju
lyc1
> already
> be made smarter, to also include "ossp_uuid". But the dependency in FFS
> makefile (currently) is not correct: target "FreeFileSync" depends on
> "ossp_uuid", while in fact only "shared/guid.cpp" should depend on
> "ossp_uuid". Could this be fixed by having "shared/guid.dep" depend on
> both "shared/guid.cpp" AND "ossp_uuid" (possibly without removing
> "shared/guid.cpp" from file list)?
Hum, it a bit dark for me. It seems to be a compiled-time issue, so doing a
third party package which includes ossp_uuid (libfreefilesync ?) doesn't help.
I don't know what to do but I think it would be good to package FFS and RTS in
separate debs.
> it. And the other extensions, *.ffs_batch and *.ffs_real are not
> registered.
Ok for the icon, I'm going to see how to do that.
*.ffs_batch and *.ffs_real have to be registered with FFS too ? or later with RTS ?
in separate debs.
Forget the point I mentioned (for now)! We're lucky here, the point I
mentioned currently is not relevant! (An older release however had this
dependency, but for v3.3 I had reworked this algorithm, so that right now, we
should be fine.)
with RTS ?
If you provide two distinct packages *.ffs_batch would go with FFS and
*.ffs_real with RTS.
But the question is, do we really need two packages? The only difference
between FFS and RTS is the executable, all other files are shared between the
two. So I think it makes sense to also publish them together. This is the way
the Windows-installer is designed, so it would be nice to have this approach
harmonized with Linux.
lyc1
> This is the way the Windows-installer is designed, so
> it would be nice to have this approach harmonized with Linux.
Users are not the same, it isn't so important that both bundles look alike.
Anyway, next days, I'll push a new version of the deb package which will
include RealtimeSync executable.
Alright, thank you!
lyc1
I published a new versio of the deb package a few time ago.
It includes :
- FFS 3.4rc2
- Realtimesync
- New modifications in Makefile (better clean target)
- PNG menu icons are automatically extracted from .ico files instead of using xpm files
In Makefile, I had to change this
cd shared/ossp_uuid && make clean
by this :
cd shared/ossp_uuid && chmod +x configure && chmod +x shtool && ./configure
--with-cxx --disable-shared && make clean
I'll do later icon associated with ffs files.
During deb packaging, I can see these warnings :
dpkg-shlibdeps: warning: dependency on libwx_gtk2u_richtext-2.8.so.0 could be
avoided if "debian/freefilesync/usr/bin/RealtimeSync
debian/freefilesync/usr/bin/FreeFileSync" were not uselessly linked against it
(they use none of its symbols).
dpkg-shlibdeps: warning: dependency on libwx_baseu_xml-2.8.so.0 could be
dpkg-shlibdeps: warning: dependency on libwx_gtk2u_aui-2.8.so.0 could be
dpkg-shlibdeps: warning: dependency on libwx_gtk2u_xrc-2.8.so.0 could be
dpkg-shlibdeps: warning: dependency on libwx_gtk2u_qa-2.8.so.0 could be
Do you know how to remove them ?
Good!
Why is it necessary to configure before clean-up?
> During deb packaging, I can see these warnings:
`wx-config` links against all available libraries by default. So unless one
specifies all required libraries manually (which is not a good idea with
regards to long term maintenance) I see no way to avoid these warnings.
Additionally: Using `wx-config` for compiling and linking is the official way
to do this.
lyc1
You're right, here is much better way to be able to call "clean" target even
if ossp_uuid configure has never been called.
Replace "cd shared/ossp_uuid && make clean" by
if ; then cd shared/ossp_uuid && make clean ; fi
Warnings are warnings, I will just ignore them.
For the future inclusion in Ubuntu, it would be good the see a license header
in each text file.
Do you know what is the license of your images ?
Why not simply "cd shared/ossp_uuid && make clean". There is nothing that can
go wrong with it, is there?
header in each text file.
> Do you know what is the license of your images?
The images have various licenses, but all are fine with Open Source usage, I
checked this explicitly.
And as for the text files, I'm not sure if I want to cluster them with this
redundant license headers.
I don't think it is really legally required as the license becomes obvious at
a number of other places.
lyc1
> There is nothing that can go wrong with it, is there?
Yes, if configure has never been called, Makefile doesn't exist and "make
clean" fails.
Source deb packaging process begins with "make clean" which calls "cd
shared/ossp_uuid && make clean". As ossp_uuid Makefile doesn't exist, it
fails.
I don't know If there is a better way to handle this issue.
> them with this redundant license headers.
> becomes obvious at a number of other places.
There is not need to do that quickly, but according to
https://wiki.ubuntu.com/PackagingGuide/Complete%23Copyright
"For all files it must be clear under which license they fall. Source code
files should usually have a short comment at the top which points out the
license."
Your IDE could managed that for you seamlessly.
I did a "grep -ir copyright *" on FFS, and, waoh, there are many external
files, with their own license.
I will have to add them to [404, Invalid URL: http://bazaar.launchpad.net/%7Edlecan/%2Bjunk/ffs-devel/annotate/head%3A/debian/copyright] if they are not GPLv3.
clean" fails.
You're right, in this case the existence check is okay.
The external packages I use are:
wxWidgets (http://www.wxwidgets.org)
-> http://www.wxwidgets.org/about/newlicen.htm
Boost (http://www.boost.org))
-> http://www.boost.org/users/license.html
Inotify (http://inotify.aiken.cz/?section=inotify-cxx&page=about&lang=en)
-> GNU GPL version 2 or GNU LGPL version 2.1 or a X11-style license
Loki (https://sourceforge.net/projects/loki-lib/)
-> MIT License
Ossp UUID
(http://www.ossp.org/pkg/lib/uuid/))
-> http://www.ossp.org/doc/license.html
TinyXml (https://sourceforge.net/projects/tinyxml/)
-> zlib/libpng License
lyc1
Thank you for this list of licenses.
