.sync.ffs_db vs. sync.ffs_db
arneko
Dear Zenju,
I am using FFS sync quite happily in a multiplatform environment (Linux and Windows, that is. I often miss it when working on a mac though)
As a multiplatform user, something that bugs me is, why many programs choose
-files marked as invisible on win Platforms
-files with a dot as first symbol on *nix systems
(that is true for many programs, not just FFS)
for their configuration files, databases etc.
In my opinion, it would be quite simple to do both:
-put a dot in front
-mark it as invisible
(at least on MS-filesystems, since I am quite positive that you can't mark anything as invisible on *nix filesystems)
While I am not sure if *nix implementations of FAT or NTFS support marking a file as invisible, I am pretty sure that Windows supports naming files with a dot as first symbol.
So why the hassle of having different names? In the past that seemed to make sense, since FFS used different formats for Linux and Win (+32vs64 bit!), but if I understood your changelog correctly that isn't true anymore.
So is there a deeper reason behind this that I cannot grasp, or is it just the legacy of darker times? If so, I would welcome the switch to .sync.ffs_db on all platforms. Even if Linux users might be the only ones who benefit from that...
Thanks for the great program!
Arne
The 32 and 64 bit file format were unified some time ago. But there are at least these differences between Windows and Linux: Latter contains case-sensitive file names, former case-insensitive. The optional file id representations may be different for the same files mounted unter both OSs.
arneko
The 32 and 64 bit file format were unified some time ago. But there are at least these differences between Windows and Linux: Latter contains case-sensitive file names, former case-insensitive. The optional file id representations may be different for the same files mounted unter both OSs.Zenju
Point taken. Though I must say, the implications of case sensitivity vs. insensitivity are just mind boggling in a multi-platform environment. Gives me a headache.
Simply astonishing... :-)
