As the program currently is, when you enable versioning, presumably the "versioning" folder will grow and grow over time, potentially filling up the drive it is stored on.
It would be good to have configurable controls to limit this.
For example:-
1.
A configurable number of previous versions to retain, with the program deleting the older versions on each run. ie, you could say only retain 5 previous versions of files.
2.
A date limit that old versions are retained. ie, you could say only retain previous versions up to 6 months old.
There may be other types of controls that could be used as well.
And possibly even a combination of both of the above?
[Feature request] Ability to choose number of previous file versions to be retained
