feature request
b-ou
[SOLVED]
would it be possible to let the user choose the recycle bin manually? I
sync to a network drive that has a recycle directory that ffs does not use.
So if I could choose the directory myself I could override this problem.
And instead of just moving the files over there, it would be nice if ffs
would create a folder with the date, so that the user can easily decide
which folders should be deleted permanently. Thanks a lot for this already
great tool!
b-ou
b-ou
I just realized that it already works with File Versioning. We can close this request. Thanks a lot!!!
