BUG: Using copy on mac inside filters CLEARS the filters
Using copy (Command C) on mac inside the filters dialogbox CLEARS ALL the filters, as it seems to trigger the "clear" button. This means I can't copy and paste filter lines in the exclude section of my project. Very annoying. Suggest choosing a different shortcut key for the "clear" button.
This seems like another wxWidgets bug where button label access keys incorrectly take precedence over short cuts of a standard text control with input focus, as in:
http://trac.wxwidgets.org/ticket/11320
I'm not sure if using "`command + <char>`" for button label access keys is the default behavior for OS X applications in first place, so there's probably a second wxWidgets design issue here.
Until wxWidgets fixes these issues in the decades to come, I'll rename "Clear" to "Reset", to make the FreeFileSync filter dialog workable again.
