RealtimeSync Idle Time not working at long durations
RageX
When I set the idle time to 10 seconds, everything works fine. However, when it is increased to say 600 seconds, or 3600 seconds, the sync is not activated after the stipulated time. Is this a known bug and is there a fix for this?
Supraman88T
+1 for this post. I've found that any setting up to 30 seconds works fine, over 30 seconds does not seem to work.
Note that "idle time" is *not* a delay: The problem is, the longer you set the minimum idle time, the less likely it is that such a long time span without any wite operations actually exists. The goal of this setting is to find a time span where the folder is not currently under heave use so that synchronization won't interfere too much.
