Files (and not folders) sync
ahnico
Hi everyone,
I would like to synchronize files from one source to several destinations.
Explanations:
- I've one folder with several files, and I would like to sync each file with the same file inside a dedicated folder.
I've attached a picture, it should help to understand what I mean, I hope....
All I could do was just a folder synchronisation.... :-\
Thanks for your help
Nicolas
I don't understand the reason for your use-case, but if that's what you want ...
After you first manually create the DestA, DestB and DestC folders
you can create a FFS sync with multiple (three) left-right folders pairs:
Pair1: left: Source; right DestA,
and change the Pair1 specific include filter from "*" into "FileA"
Pair2: left: Source; right DestB,
and change the Pair2 specific include filter from "*" into "FileB"
Pair3: left: Source; right DestC,
and change the Pair3 specific include filter from "*" into "FileC"
ahnico
Perfect thanks a lot.
I did not notice specific filter per Pair.
