NTFS Permission
josephtan
Hi Everyone,
I just started using freefilesync not sure if i did anything wrong.
On first sync from my source to destination the NTFS permission was replicated successfully.
However, if i made any changes to my source folder permission, my destination folder does not reflects the changes.
I tried doing a manual sync, it did not work. Using RealTimeSync did not work either.
Is there something i doing wrongly
pkuo
Were you able to find a solution for this problem?
A thought about your issue is maybe try delete the destination folder that didn't inherit the permission and resync it?
not the best, but it's an idea.
