Hi all . . .
Forgive me if I posted a question already posted or known. English is not my language and it is very difficult for me to try a thousand posts.
I would like to know what is the sequence of job Free File Sync, in relation to the list that appears on the main screen.
That is, if for example, the first job to be executed, it is first on the list at the top, or on the last bottom. Because this makes a difference.
That said, I would like to know how to enter - in the same job (same batch) - a new task, which however must be executed after another task.
(Or even before).
From here my suggestion: why not make "editable" the tasks list also within the Free File Sync, so as to "move" up or down a given task, that needs to be moved without having to recreate a new task.
I conclude by thanking the authors of this excellent program that works daily and that makes me live peacefully
Wat is job sequence in relation to the list shown - and suggest
