Lock disabled, but still locks directory
secondstory
We've set "LockDirectoriesDuringSync Enabled" to false in the GlobalSettings xml file, but we are still intermittently seeing directory locking during sync. Is there a way to permanently disable the directory lock? It doesn't lock about 90% of the time, but other times the sync.ffs_lock file is still generated.
Thank you!
The setting is surely evaluated but you might be experiencing a problem like this one: viewtopic.php?t=650
