File sync is crashing my computer
salevine
My computer keeps crashing while the file sync is running. I have the memory dump and am happy to share it if someone can tell me how to stop this from happening. The dump is 1.3GB so I can't really put it here. Actually. I am uploading it to a dropbox and will share the link later.
What do you mean with "computer keeps crashing"? If the operating system crashes, there cannot be a FFS dump file. So it is the FFS process that is crashing and you see a notice to send the dump file?
salevine
FFS is causing my computer to crash and reboot. In the windows event logs I see a bugcheck event. The dump file is here: https://www.dropbox.com/s/85iwt1ws5oyvy76/MEMORY.DMP?dl=0
This is not a FFS dump file but an operating system crash dump file. It is not a problem caused by FFS (OS crashes are caused by driver or OS bugs but never by user-mode applications), but I had a quick look anyway:
You have a BSOD of the following kind, crashing at "nt! ?? ::FNODOBFM::`string'+0x15dab":
http://superuser.com/questions/1043592/memory-management-bsod-memtest86-showing-no-issues
