Will this program allow me to sync to a NAS drive?
Can I also sync to a cloud service?
Thanks for the help
-Eds
Noob needs help with sync
Well, I'm a noob, too - but I am syncing to a Western Digital My Cloud box, and to a cloud app I use called Sugarsync. It should sync to just about anything you can reach from the system running FFS.
I suppose you need to think about, and test, issues such as file locking if another system is updating any remote data during your sync, and the overhead of comparing your files to those on the cloud - you don't want it to download everything everytime - if you are comparing based on file content, for example.
Hope that helps
Dan
Hope that helps
Dan
