Chinese Folder Name in Mac
cliffstar
I'm new to FreeFileSync software. I just notice that if some folder is named with all Chinese letter(e.g. "測試"), it will cause error when comparison start.
The error show:
Cannot enumerate directory /Users/work_caesar/Desktop/TEST/////////////////////////////////////////////////////////////////////////////////////////////////////TEST2.
Endless recursion.
I've made a test: If I change the beginning of the folder name with "_" (e.g. "_測試"), the comparison will be ok.
Could you fix the bug or what can I do to prevent the error? I don't want to rename all the Chinese folder name.... There are tons folder in my disk...
cliffstar
Thanks! High speed reply!
You fix it with amazing efficiency!
It works fine now! Wow
