bidirectional sync between multiple computers
patrix87
Sorry if this is a duplicated question, I looked at the search and could not find it.
I have a question regarding bidirectional sync between multiple computers through multiple drives.
Let me explain my situation.
I have 2 location. each have a computer in them.
I use 2 hard drives for backup that I exchange from one location to the other every week.
Computer A & Computer B
HDD 1 & HDD 2
On Friday I sync computer A on HDD 1 and leave for Location B
Every Day Computer B sync with HDD 2
On Monday morning I swap HDD 2 for HDD 1 and leave location B for Location A with HDD 2
On Monday night I put HDD 2 in Computer A and Sync Again.
Both location will modify the same folders and the modification should be reflected on both location.
Example: I delete a file from Folder X on Computer A and I add a file to Folder X on Computer B on the same day.
That night Computer B will sync the backup drive.
On the Friday Computer A will sync the backup drive
On Monday I swap the drives and on Monday night computer B and A will be sync and the file should be removed from both and the new file should be in both.
In more technical terms;
How does the bidirectional sync actually work.
Does it use a local database of file ? (which would not work since I have 2 computer)
Does it use a database of files on the backup drives (which could cause issues since I have 2 backup drive that I swap every week)
Does it use a database at all ?
Thanks for your help.
Your scenario is well-supported. FFS database files are stored in each data location and it doesn't matter how many data sources participate in a FFS "two-way sync".
