syncing of files that have not finished being written
brad-at-io
we work with large files that can take several minutes to write to disk and we're having trouble with FFS syncing unfinished files. eg quicktimes movies being generated.
Is there a way to tell it not to sync files that are still open/being written to??
Would switching off "copy locked files" fix this?
BTW we have tried extending the delay time but it woould need to be 10+mins to be safe and it becomes less useful at this point.
Yes
brad-at-io
We're still having the same problem, despite having "copy locked files" off.
Any other suggestions?
Any other suggestions?brad-at-io
FFS cannot sync locked files without VSS, so the settings must still be on.
brad-at-io
Nope. Not on. See attached jpg screengrab.
Is there any other place this setting can be active and overiding what I see in the FFS GUI?
Just watched an incomplete quicktime get synced (& finish syncing) while the original file has still not finished being written yet....
...still hasn't...
...now it has!
original file: 119,933KB - modified timestamp: ‎19 ‎September ‎2014, ‏‎16:37:22
sync'ed file: 56,320KB - modified timestamp: 19 ‎September ‎2014, ‏‎16:36:28
Going over our quicktimes that have been sync'ed over last few weeks, about 50% are incomplete & corrupt on our server now. Getting VERY concerned, as it will take very careful manual syncing now to rebuild.
brad-at-io
As Yoshihiko Mori is also having similar issues with video files in:
viewtopic.php?t=236&p=839#p839
...I'm wondering if maybe the quicktime/video files that are being created are not constantly locked until the writing finishes...
...or not.
...or not.brad-at-io
That's possible. You can test this yourself: Just try to copy such an incomplete file via Windows Explorer and see if it works.
brad-at-io
Confirmed.
I can copy incomplete quicktimes that are still being written to....
