FFS 6.9 on Windows 2012R2
If I mirror 2 directorys I get wrong timestamps of files in the target directory.
The timestamps updated with actually copy time.
This happens onely to known files like (.PDF, .Doc, .TXT, ...) unnown files (.dat, .xyz) get the correct souce timestamp.
This happens onely in the root directory, if I move the Files up in a directory there is no problem with the timestamps, also all other subdirectorys have no problem.
Any ideas to fix my problem?
wrong timestamp of mirrored files in target directory
Can you create a minimal sample and log a Process Monitor trace of such file copy operation that doesn't set the correct time?
OK, but I have to setup a testsystem for your logs, i cant do it on my productive system (IT Security). Sorry - takes a little while.
Process Monitor is a tool developed by Microsoft, so running it shouldn't be a security issue if you ask your admin. OTOH I doubt you're able to reproduce such a peculiar issue on another system easily, but if you can, the logs of this system are just as good, of course.OK, but I have to setup a testsystem for your logs, i cant do it on my productive system (IT Security). Sorry - takes a little while.flipp1899
