I'm using version 8 on windows 7. I created a batch job and the batch job works fine when i run it manually i.e. I double click the "job file" and it starts running fine.
If i schedule the same job using windows task scheduler, I get the following error in the logfile:
[13:39:24] Info: Starting comparison
[13:39:29] Info: Cannot find the following folders:
\\198.168.130.2\tms
\\198.168.131.2\tms
If you ignore this error the folders will be considered empty. Missing folders are created automatically when needed.
-> Automatic retry in 5 seconds...
For some reason when running it as a task it does not want to recognize the path?
"Folder not Found" when running batch job
Try again with the new beta version, chances are that you'll see a more detailed error message:
http://www.mediafire.com/download/1gq2scrl4dxm55u/FreeFileSync_8.1_beta_Windows_Setup.exe
