I have used FreeFileSync to synchronize entire drives. Now I want to do that again, but I want to do it one folder at a time, or just a couple of folders at a time. I can't see how to select one folder on my source drive and simply copy it to the new drive? The view shows ALL the files, in every folder, on the whole drive. Is there any way to just have it show top-level folders and let me choose which ones to sync over to the new drive?
Bob
How to simply copy a folder? Duh
just create one or more new sync configurations with only the folders you want to sync on both drives; set your sync preferences and go (obviously, you can delete (or at least don't run it) your previous "full drive" configuration)
