Hello..
I use FreeFileSync for years now.. With an old V5.13...
For using USB-Harddisks I write a smal GUI whitch use your batchfiles.
So when my tool runs (as App or service) and i plug a prepaired USB-HD to the PC it use a joblist from this HD, create a batchfile and start it with FreeFileSync.
Now I have made an update (V 7.9, need portable) and the format of the bathfile have changed.
Could you give me a description, witch changes to the batch are made on witch version?
Best regards
Holger
Format of Batch XML
