ShellExecuteEx
heichhj
I am a new user of this bright tool! I made several tests with a number of options and thought I can use it now also on a network drive. But I am experiencing a problem:
- I have a job that mirrors a set of folders to a drive on my local network. But when I try to use I get one critical errormessage: It complains a file "ShellExecuteEx" is not found (see attached screenshot)
Is there a solution/explanation?
Regards
Hermann
Ship Shape
FreeFileSync used to close after completion. Following a recent update I am now getting this error at the end of a sync. How can I cure this?:
Incorrect command line:
File: “Close”
Arg: Progress Dialog
Error Code 2: The system cannot find the file specified. [ShellExecuteEx]
