The menu bar icons for FFS and RTS are in full color, which clashes considerably with the rest of the menu bar.
As of yet, I have not been able to find the correct icons to edit in /Contents/Resources/Resources.zip.
Can we be provided with some grayscale icons for the menu bar or better yet, could someone point me to the correct place/way to create them myself?
Thanks in advance.
menu bar icon for OS X version of FFS
Is this just some personal preference or about an Apple guideline?
It's not an official Apple guideline that I know of, no. However, all official Apple menu bar icons are greyscale and I've yet to use a 3rd-party app that had color menu bar icons. This is app is the first I've used that uses a color icon and it's red as well. Blue would be better than red, though again, greyscale would be ideal.
I love your app and I know you have more important things to focus on, so that's why I asked if I could change them myself.
FFS doesn't show a menu bar icon. Maybe you mean the icon in the notification area while RTS is running? If not, can you post a screenshot?
The entire top bar is the menu bar. The right-hand side where the icon appears is actually the status menu.
http://support.apple.com/kb/HT3737
It's really not that big of a deal. The program works great and I really like it. I'm sure you have more important things to deal with anyway. Maybe if you get some time you could make it a future enhancement.
