Since having issues with my macbook air (FFS won't run/open, see separate topic on this forum) i decided to check for a newer version of the download, only to find the Mac version gone?
Is it taken offline?
Cheers,
Marius
Mac version gone?
Yes, where is the Mac Version? Why is it gone...I am still being prompted to update the software but there is none for the Mac. Advise...Thanks!
TIL "+" != array_merge for flat arrays. Fixed! The OS X download is shown again.
