Please, how can I set a tolerance of a few seconds? This is nothing to do with daylight saving, but some of my files have a timing difference of 5 or 10 seconds. All the posts on this are old, and suggest that one has to alter the source code. But surely there must be a setting somewhere? If not, what should I do? This is a brilliant resource, but it is reporting that hundreds of files are out of sync, when in fact they are not.
Any help would be very much appreciated.
Tolerance
You're looking for the global option FileTimeTolerance
Many thanks!
