Thanks for your VERY useful utility. I use it a lot.
There is something bizarre when, after having successfully synchronized a directory with my laptop, I try to synchronize a second directory tree.
Although I select both directories in FreeFileSync, the program seems to remember the previous directories names and says that both directories are already in sync.(nothing to sync)
I need to exit FreeFile Sync and restart with the new directories access path, then it works as expected.
That behaviour occured already with the previous versions.
Regards.
Yves
Freefilesync synchronize a second directory tree
You don't need to restart FFS to update the comparison, just compare again (F5).
