I noticed this on the previous version when I upgraded to the latest version and I'm still seeing it.
I exited out of both FFS and RTS before upgrading to the latest version and when I tried to copy the new apps, I was given a warning that the apps were in use and could not be updated.
If I go to File | Quit in FFS or if I click on the Status Menu icon for RTS and select "Quit", the programs appear to close correctly.
However, if I then look at running processes, both FFS and RTS are still running. The only way to terminate them is to kill the process.
Mac OS X version 6.10 not terminating FFS and RTS processes on exit
This is a side-effect due to the FFS launcher mapping the OS X MDI concept to the FreeFileSync app. I'll see to implement a fix that solves this limitation.
Until then the workaround is to restart OS X or to quit the FreeFileSync process in the OS X Activity Monitor.
OK cool. Thanks for the response.
I've updated the FreeFileSync launcher to automatically exit once all of its child processes (= FreeFileSync windows) have ended. This should fix the issue discussed above.
Here's the new version for testing. Let me know if there are still problems:
[404, Invalid URL: http://freefilesync.sourceforge.net/FreeFileSync_6.11_beta_Mac_OS_X_64-bit.zip]
I will test it tomorrow and let you know. Thanks for all your hard work!
Thanks, I've been having the same issue and now it works perfectly.I will test it tomorrow and let you know. Thanks for all your hard work!htismaqe
Sorry for the late response. I had a drive die in my NAS and I made the mistake of installing OS X Yosemite over the weekend.
I have confirmed as of this morning that this problem is fixed in the 6.11 beta.
Thank you for your efforts!
