Hi all,
making a completely flexible filter system is hard, if not impossible. However, i think the current system could be greatly improved with the includion of an additional set of rules for a force include. This would modify the behaviour this way:
"an item is included if it matches a rule in force include, or if it matches a rule in include AND none of the exclude rules".
Usage scenario:
I have folder1 which contains a number of files and subfolders, among which folder2. Folder2, in turn, contains a number of subfolders among which some have a name that can be singled out easily with a filter (let's say the many include "syncme".
I want to sync all the files and subfolders in folder1, with the exception of folder2, for which I only want the subfolders marked with "syncme" to be synced.
Currently, I don't see a way of doing it (if not creating two jobs).
With a force-include set of rules available, you could do something like this:
base folder: folder1
include: *
exclude: folder2
force include: \folder2\*syncme*
I'm sure there are many other usage scenarios. I just happen to have this specific problem... would it be really hard to implement?
Feature request: force include
You can achieve this by using two identical base folder pairs:
Folder Pair 1:
include: *
exclude: folder2
folder Pair 2:
exclude: [empty]
Folder Pair 1:
include: *
exclude: folder2
folder Pair 2:
exclude: [empty]
Besides my thanks for the reply, I owe you my apologies for the question itself.
I did not realize that there was the possibility of setting local filter for every filter pair. With this possibility, the solution is indeed quite obvious.
Thanks again.
Giacomo
Thanks again.
Giacomo
