windows 8.1 and free file sync
pastoru
I am trying free file sync to back up my files to external locations. It works fine when I sync manually. But I can not get the program to start automatically by my task scheduler. I want to program to sync files automatically when I start my computer. Can someone help me get it to work. My platform is windows 8.1.
thanks.
pastoru
IS there none that has an answer?
You are an impatient man ... (only 6 hours between initial post and "reminder")
All info is in the help-file.
(Don't have access to that now, but ...)
For Windows Task Scheduler you have to enter the full command-line instruction:
the FFS executable (incl. its full path), the correct options and to specify
the desired *.ffs_batch sync configuration-file (incl. its path),
and not just enter the *.ffs_batch -filename.
