FreeFileSync 8.3 does not run on Linux (Opensuse)
corneld
I just tried to use the newest FreeFileSync (version 8.3) on my Opensuse Leap 42.1 system.
Unfortunately, it refuses to start.
Due to this error:
./FreeFileSync: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.22' not found (required by ./FreeFileSync)
Of course, libstdc++.so.6 IS there, in the system. Or, to be more exact, it is a link to /usr/lib64/libstdc++.so.6.0.21
I had to revert to version 8.2 of FreeFileSync in order to keep using it.
Any idea why did it throws this error ?
Thanks.
P.S. To eliminate any possible misleads, I use an OpenSUSE Leap 42.1 64 bit; package libstdc++6 is installed
corneld
OK now ... as far as I can see on any Opensuse repositories, the latest libstdc++ version available is 5.4.0 (or, to be more exact: 5.4.0+r237057-80.1 in Opensuse terms).
The latest string of GLIBCXX included in this library is still GLIBCXX_3.4.21
So ... please, can anyone tell me what version of libstdc++ was compiled against at your (Freefilesync) side ?
Thanks.
