If I sync a folder containing some files and empty subfolders, they are all correctly copied in the target location.
However, if I set the deletion handling option to versioning and define a specific folder to move to deleted parts (like "c:\backup\Deleted\%timestamp%") ... only deleted files but not deleted empty folders will be moved to the deleted parts folder.
It could be problematic if the structure of the subfolders (even empty ones) have to be kept (and thus retrieved if mistakenly deleted).
Is it an expected behavior or a bug ?
Arnaud
empty folders and versioning
This is by design and - so far - nobody has complained about it, so I hope it is useful.
Ok, but if I am complaining ? :-)
Is it possible to add an option somewhere to keep them even if empty ?
