I have a batch job where "Save Log" in set to on.
If I use:
"C:\Program Files\FreeFileSync\FreeFileSync.exe" "Test.ffs_batch"
that works, assuming Test.ffs_batch is in the current directory.
If I use an absolute pathname:
"C:\Program Files\FreeFileSync\FreeFileSync.exe" "D:/FreeFileSync/Test.ffs_batch"
that fails, FreeFileSync trying to use a mangled name for the log file.
Thanks for a great product anyway!
Unable to create log file in batch mode
What were the exact error messages you saw and the FFS configuration you used?
I get:
Cannot write file "d:\m1\FreeFileSync\Log\D:/m1/FreeFileSync/Test 2014-10-31 13571.log"
Error Code 123: The filename .... is incorrect.
What happens is that the full path is attached to the log directory, rather than just the name of the log file.
It should be just:
"d:\m1\FreeFileSync\Log\Test 2014-10-31 13571.log"
I attach the config file.
It should be just:
The problem seems to be related to the "/" characters. How do you start the ffs_batch job? Are you using "/" instead of "\" somewhere as path separator?
Can answer this myself, it's in your first post, this is the problem:The problem seems to be related to the "/" characters. How do you start the ffs_batch job? Are you using "/" instead of "\" somewhere as path separator?Zenju
Ok, got it!
That's because of my Unix background, I often use "/" instead of "\".
It's easy to correct on my side of course, so I'm happy, but it's still a (little) bug. FFS should handle / like it does \, since both are allowed on Windows.
Anyway, thank!
Anyway, thank!
Implemented for 7.4. In addition FFS will accept macros, path by volume name, etc, i.e. it supports all directory parsing features now also from command line! So something likeOk, got it!
Anyway, thank!bob-125
FreeFileSync.exe %csidl_desktop%/Syncjob
will run. Note the slash instead of backslash and the missing ".ffs_batch".
[404, Invalid URL: https://www.mediafire.com/folder/hekh49j9hahyy/Beta]
