copy files AND exclude dest folder structure
iaddicengineer
Hello All: Does anyone know if it is possible to use this tool to locate all files in a source location c:\*.pdf for example and copy them to a destination location c:\all_PDF_Files\ for example but NOT have the source location directory structure. I am just looking for the files to be copied to the one folder. Hence whenever i add a document of the type PDF to my computer, when the scheduler kicks off FreeFileSync, the new files would be added to the destination directory. Hence I maintain a relatively current library of all pdf files on my system.
Thanks,
If the directory tree is static and not very complex, you should be able to use multiple folder pairs.
The A locations would be the different folders in the source folder tree
(but obviously not C:\all_PDF_Files\ )
the B locations would all be identical same destination folder C:\all_PDF_Files\
The (global) Include filter could be "*.pdf" (excluding the quotes)
The (global) Exclude filter should contain "\*\*" or "\*\*.pdf" (excluding the quotes, either one should work)
No need for local (individual A/B pair) filter settings.
Select the (left-to-right) Mirror sync method if files that no longer exist in the source folder must be deleted from C:\all_PDF_Files\.
Select the (left-to-right) Update sync method if files that no longer exist in the source folder must remain in C:\all_PDF_Files\.
With your approach you need to assure yourself that no identically named pdf-files exist anywhere in your source-folder tree.
I have no FFS-based suggestions for a dynamic and/or complex folder structure.
It seems that then a specific batch/cmd script would be more appropriate.
This script would traverses the source folder tree (C:\, excluding C:\all_PDF_Files\ ) and copies each pdf-file to C:\all_PDF_Files\ if it
does not yet exist there or copies/overwrites each pdf-file already in C:\all_PDF_Files\ if that file in C:\all_PDF_Files\ is older than the one in the source folder tree.
iaddicengineer
Hi Plerry, I am dealing with a fairly complex directory structure and in some case 4 or 5 levels deep. My challenge seemed simple at first. Essentially all I want to do is create a Library of PDF Files without moving the originals. I use an app called evernote and I want to connect that folder to the evernote watch folder feature. Then I can tag and manage the library from there. Looks like the script method may be the best route. Thanks for your reply.
