FFS 6.9.0.0 crashes - empty crashdump files
duewest
Hi Guys,
I've got FFS 6.9 installed (64 bit version) on a W7Pro64 SP1 PC that was syncing a mapped NAS drive as N: to a local disk D: as a backup of the network shared files.
It uses the RealTimeSync to execute every 30 minutes, and was working beautifully until a couple of weeks ago. Every time FFS runs it generates a 0 byte CrashDump file on the desktop and no explanation as to why is it failing...
I uninstalled FFS and installed again, but the same thing happens.
I ran FFS directly to see if it would crash using the interactive version, and it asked me to upgrade to 6.11 so I did that just now and ran the RealtimeSync again which started the FFS sync which I opened from the System Tray to monitor progress.
It ran perfectly!
So I'm posting this anyway just in case someone else has had the same problem with 6.9.0.0 (or another older version) with empty crash dump files filling up their desktop and needs to know how to fix it!
Thanks for a great little program!
Cheers
