Help on upgrading Filesync Portable
dlapish
For some reason when I run the 6.12 setup for Windows everything updates except the portable version (which is the only one I use). The executable file remains: FreeFileSyncPortable.exe, 02/10/2013.
I am running Windows 8.1 with admin rights. I accept the license agreement, then change the installation folder to the existing folder on the USB drive. At the next screen I select Portable and deselect the shortcut creation. The installer then runs but the above portable executable is unchanged.
Am I doing something wrong?
Thanks.
