When I manually run the batch file, it works without issue. When I follow the instructions for using the windows task manager I get the following message:
After a reboot, after 11am (when the task is scheduled to run), it is always running as a status.
An Instance of this task is already running. (0x8004131F)
Task trigger is a time daily.
"C:\Program Files\FreeFileSync\FreeFileSync.exe"
"C:\Users\richtj99\Google Drive\raidsync-12-2014.ffs_batch"
Again it works fine if I click on the batch file itself. I see the icon in the task bar, it works great.
If i leave it up to windows, i see nothing at all, no icon, no file changes. And the task manager always has the same error.
Any advice would be great.
Thanks,
Rich
FFS - Windows 7 Batch Mode Issues
