My Tree Overview Panel is blank. It does not show any directories. How do I get it to show directories?
Thank you
Tree overview panel
Have you (already) selected (at least) a source folder & run a Compare?
(If not, Overview remains blank until you do.)
Maybe you need to change the "Select view" setting at the bottom of the screen. If all source & destination files are the same you won't see anything in the Overview panel unless you have selected "Show files that are equal".
