Source File Created as Dir on Target
dreamer451
When mirroring, I frequently have to run FreeFileSync multiple times because the target is created as a directory. Same name as the source file, but as a directory. On average it takes 3 iterations for all conflicts to be reconciled. Verison 6.12 on Windows 7 Home Premium. There does not appear to be a pattern to which files this occurs with. Example: source is "\\MyHomeServer\recording\audiobook\bookname [book author]\bookname -- 001.mp3" and target may be created as directory named "\\WDTVLivePlus\Elements\recording\audiobook\bookname [book author]\bookname -- 001.mp3"
This sounds more like a problem with the device rather than with FFS. Anyway in case you are able to reproduce this issue reliably for a certain file, then we can investigate this, e.g. via Process Monitor.
dreamer451
I am able to copy thousands of files within a hundred folders with XCOPY and Windows Explorer drag-n-drop. Unfortunately, there is still no consistency with FFS on which files or folders it copies incorrectly.
