"Cannot Open File 'GlobalSettings.xml'"
stevemb
The portable install randomly (about half the time) fails to start, with an error message "Cannot Open File 'GlobalSettings.xml' -- Error Code 32: The process cannot access the file because it is being used by another process. (Create File)"
dr-n0
For me it helps starting bin/FreeFileSync_x64.exe (or _Win32.exe or _XP.exe) directly .. but only randomly as I experienced now :-(
