Which setting in the xml file changes the default height of the "Synchronization Settings" window?
tsmarll
I like to view all of the "exclude" filters that I have installed without having to scroll the exclude filter window or manually resizing the entire "Synchronization Settings" window.
I've looked in the xml file and I'm sure the setting is in there, I just don't know where.
If this can be done as simply as I think, could you tell me which settings it is? Thanks
