Hi
Is it possible to sync three folders at a time?
I can't seam to add a third folder in FreeFileSync. I can add the extra folder in RealtimeSync but as I read it, it only watches the folder for changes, but I then need to start a .ffs_batch which only syncs two folders.
How would you attack this?
Running windows 8.1 x64 two locations is network paths one is local.
I currently have two RealtimeSync running which works, but it could be nice to get them consolidated.
Regards Lars
Three-way sync
Not sure what you mean but I think you need to sync one to the other then do the same again. I do a LAN_WAN sync, the LAN is (my docs, my music, my vids....and so on) the WAN is Microsoft OneDrive. Then my next sync in from OneDrive to my NAS which is local to me. I tried doing it all with one run but I would keep getting errors so I have to run 2 separate batch files a couple of minutes apart.
