Your RealTimeSync Manual example is in Windows syntax. Being a mouse monkey I'm not a big terminal user so I'm getting hung up on how to write the command to run the RealTimeSync job. I use Ubuntu linux and I know how to get RealTimeSync to start up automatically by adding it to my Startup Applications. However, I can't figure out how to tell it what job to do. tried this:
/home/username/location of FreeFileSync/RealTimeSync '/home/username/location of filename.ffs_batch'
Would just:
I am also monitoring both the main drive and the target drive. I believe that's correct right?
Thanks.
