Hi
Every night I have a batch Sync job that needs to run and it is trying to Sync over 1 million files and it normally takes about 1 hour when doing it manually but gets stuck running when running it from the windows task manager.
Is there a way to speed it up or know the status of the sync to see how far it is and if something is holding it up?
Kevin
Batch Sync
If you set it up to run under your normal user account, you'll see the progress in the Windows notification area (lower right, next to the system clock).
