First thanks for this excellent piece of software.
In version 8.0, I can't connect with my smartphone with "primitive ftpd" setup with sftp port 1234 . "primitive ftpd" does not allow to set sftp port to 22, and filezilla can connect without problem on port 1234. When I connect, it gives me an error with URL missing the ":1234" port.
Thanks for reading and your help
SFTP with port other than 22
The port isn't the problem here, the connection is established correctly. The error message is about a "SFTP protocol error". Either the SFTP server on the phone and libssh2 use incompatible SFTP versions or one of them has a bug. There has been a major SFTP overhaul in 8.5. Does using FreeFileSync 8.4 make a difference?
