I've installed FreeFileSync on an older machine running WinXP. The problem I have is that each time I start the app I see this message:
> The procedure entry point GetLogicalProcessorInformation could not be located in the dynamic link library KERNEL32.dll
It shows up 6 times (have to close six error dialogs) and after that it lets me in and the applications seems to work OK - I can compare, sync, save configuration etc.
Is there any way (install something?) I can fix those error messages?
Take care,
Alex
GetLogicalProcessorInformation error
After looking around the net a bit, it seems the issue would go away if I installed SP3 on the machine.
Can you please confirm this? Thanks :)
Take care,
Alex
Take care,
Alex
Yes, FFS needs SP3 when running on Windows XP.
