I am trying to find a replacement for FolderMatch. FFS is great, but I need to be able to select a single folder and show only the files requiring synchronization in that folder. Is this possible with FFS?
Thanks!
Select individual folders ...
Not quite sure what you're asking?
You can use an Update sync such that only files on the "left" are updated to the "right".
I want to selectively synchronize two hard drives over the internet. Files in some folders need to be synchronized daily, other's weekly and/or monthly. Because some of the files are huge and because of bandwidth and time limitations, I want to compare the two hard drives, then select a single folder and see only the files in that folder that need to be synchronized, and then select only the files in that folder that I want to synchronize.
FolderMatch can do this. Is this possible with FFS?
