Folder properties
Tejas
I would like help on keeping the folder structure and path intact.
I want to sync (Update) selected folders from my large database. But when i select the base folder, i cant see all sub-folders inside that base folder; but rather it shows all the files including that of sub-folder.
So I cannot even include/exclude the ones that i want easily.
For example, my documents has many of folders (say: F1, F2, F3, F4) but i want a few ones to sync.
If i directly select only F2, F4 folders on left side then it does not keep the folder name on right side but only soes the sync for files inside F2, F4 folders. This becomes confusing as i want the the name F2 & F4 as it is on right side.
Please advise ?
Regards,
Tejas
therube
If I'm following (which I may not be), thinking you'll need to start with "/My Documents/" & then include or exclude the particular subdirectories, as wanted, for a particular run.
C:\MY DOCUMENTS
├───F1
├───F2
├───F3
├───F4
├───F5
└───F6
So if on Mondays you only want to do F1, & on Tuesdays you only want to do F2, ... then on each run of FFS, allow or exclude the other directories that you want or do not want at that particular time.
