Hi Zenju & others,
I am trying to mirror out a TEST & PROD folder set including security & timestamps over WAN-links from Europe to 5 other file servers.
We need to have a max change of roughly 7 Gb being mirrored within 8 hours. Average bandwidth is between 2-3.5 Mb/minute.
I have seen that there is some tweaking in multiplying threads when you use sftp.
Is such tweaking also possible using the normal mirror? Otherwise I have to create a multiple set of batches for folders on lower levels in the tree.
Since I cannot predict fully where in the folder structure files are updated, I would like to prevent that.
Multiple threading possibility?
