Two Way RealTimeSync needs frequent manual execution
Squidge369
I have a two way sync setup between a local folder (left side) and a network share (right side). The share gets files from a variety of systems based on which sms alerts are generated.
The local folder (left side) is mapped via a batch script to another folder that is actively monitored by Ozeki SMS Gateway to transmit the smses as soon as alert files are dumped there.
The idle time in RTS is set to 0, and the batch script that moves files from the local folder to the Ozeki folder runs every minute (task scheduler)
After RTS initially triggers, it does not sync automatically when new files are added, or files are moved from the local folder. I have to right-click on the taskbar icon, Restore and click Start after every few minutes in order for the syncs to occur.
The server this is set up on is an old Windows Server 2003 R2 Standard Edition. Am I missing something?
RealTimeSync is expected to get a redesign including some kind of log window to help troubleshoot cases like these.
