Cannot write log file: file already exsists
maszzmic
Today I discovered that a nightly automated task, which I set up a few days ago, was not running anymore. I discovered that FFS had an error trying to write the log file:
"Error Code 80: the file exsists (CreateFile)"
The log directory consists of only 10 logfiles at this moment, ranging from <name>.log to <name>_9.log
The auto increment should just increase to <name>_10.log
Why is this not happening?
Is this related to the colon issue?
viewtopic.php?t=1679
maszzmic
No, it is not. The filenames only consist of the bath name and the auto increment number.
"webserver replication overnight _2.log" for example (don't know why it adds the space there)
Okay, then this is indeed the colon issue. This is fixed for the next release, until then you can use the previous version.
maszzmic
Allright, thank you. :) I will use a previous version until the next release.
But how is this related to the colon issue, without a colon in the filename?
But how is this related to the colon issue, without a colon in the filename?maszzmic
You can find details in the thread linked above :)
