Move Detection across Folder Pairs
henning74
Dear Zenju, please consider supporting the detection of moved files across multiple folder pairs within the same job.
Within one job, multiple folder pairs can be defined. I found out that in version 8.5 the movement of files that have been moved across folder pairs is not detected.
I have a use case that looks like this: projects/p1; projects/p2; projects/p3; [...] projects/pN
My job contains the folders: projects/p1; projects/p3
Movements of files happen (newly) between p3 and p1.
I could workaround by regression to having only one folder pair (local/projects <-> remote/projects) with the filter \p1\*; \p2\*
However, by this workaround I have the same functionality and appearance as when one job could only handle one folder pair. The main advantages of multiple folder pairs are though, as I see them, to make multiple folder pairs explicit rather than typing them into the filter, and to separate both definitions from each other, both of which I appreciated in the past. Thus my above request.
Thanks in advance and best regards
henning74
*push*
Is my proposal considerable?
Regards
Technically this is not possible with the current design which works by processing each folder pair one at a time. Also for cross-folder pair move detection it is required that all folder pairs involved are set up to create database files. However there seems to be the simple workaround of using a single folder pair for the parent folder in combination with an "include filter" that includes the individual child folders.
