Computer shuts down after files sync
It's great that as soon as I add a file, the sync process kicks in and the file is on my external drive. As soon as that lock script completes its task, my computer screen turns off and the computer goes into hibernation. As long as none of the files change, the computer stays on. As soon as I add another file or folder, right back into hibernation. Any ideas why this would happen?
When you look at the synchronization settings, there is an "On completion" menu -- there is a setting to auto-shut down. You may have inadvertently enabled it.
MPX, Thank you. Works perfectly now.
